35
Ultragrid trying to write in a cell and error message says "The column is read only" but this is not trueHello H
Hello, My Name is Paolo Bertoldo, from Italy
I am testing the evaluation of Ultimate UI for Windows forms
I use VB.NET Language
Database is SQL Server
I have a form bounded with a datasource, table adapter and bindingsource created with the designer.
The form uses UltraWinGrid for display data from a table called "Manuafctured"
One field of the table is "ProductID, contains primary keys, it is connected to another table called "BOM" with a UltraDropDown with Datasource, DisplayMember, and ValueMember, the display member is the product description (From BOM table) , and it works fine.
But here is the problem (sorry for the long description but it is a little complicated)
I have to display a value coming from the "BOM" table (it is called "StdWidthIn" and contains the width in inches of the product selected "ProductID")
For this purpose I have modified the SQL Query like this :
SELECT (This part is omitted for simplicity) ,
(SELECT StdWidthIn FROM BOM WHERE Manufactured.ProductID = BOM.ID) AS BOMStdWidthIn,
(SELECT Passes FROM BOM WHERE Manufactured.ProductID = BOM.ID) AS Passes
FROM dbo.Manufactured
WHERE (((Manufactured.LengthMt)=0))
ORDER BY RollNo, InputDate DESC, MfgDate, Manufactured.Customer
The query has nested SELECT statements but the most important is this :
In the grid what appears is the alias "BOMStdWidthIn"
During form load eveything works fine, the correct data is displayed depending on the selected "ProductID"
When I try to change a "ProductID" selection via the "UltraDropDown" have written a code in the "AfterCellListCloseUp" event of the grid to modify the "BOMStdWidthIn" column according to the new value but this error appears:
The column "'BOMStdWidthIn'" is read only
The piece of code is this : e.Cell.Row.Cells("BOMStdWidthIn").Value = [some value here]
even if I try to edit it manually it is not possible but the "CellActivation" value is "AllowEdit"
My consideration is that maybe the grid cannot write a value in a column coming from the alias "BOMStdWidthIn" that is related to another table ("BOM") , not the table directly connected with the grid ("Manuafctured")
But I am not interested in changing the "BOMStdWidthIn"  value, only display in the grid.
Hope the description was exhaustive
Thank you
Paolo Bertoldo
