685
column size for 7.2 build grid
 Never mind - if I add groups then the size does work.
Think perhaps there is a bug and size should work even if there is no group.
Original question preservered below.
I have a form with three datasources on it
There is one ultragrid
The drill down works fine.
But column size does not.
If I choose "use row layout" i am denied the column pinning/freezing.
So "use groups and levels" is preferable.
How can i resize columns ?
If i need to use "use row layout" then how do i pin columns?
I have created a northwind example so simply amend string to connect to your local northwind.MDB
NorthWindCutdown.rar
