Hi, I have a situation with using the ultragrid that is upsetting our users a lot. I have partially fixed, but really there yet.
We have setup autocomplete so that if a cell has existing values they appear as autocomplete options that filter down as the user types (works very nicely), however we have a scenario that crops up a lot that goes wrong:
Say we have an existing value like 1234A but want to type a new the new value 1234a then after typing 1234a and clicking away from the cell or pressing TAB and so on the the cell value gets set to 1234A. Making it impossible to enter the lower case a as desired.
I have partially fixed by using:
col.ValueList = vl; col.AutoSuggestFilterMode = AutoSuggestFilterMode.StartsWith; col.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Suggest; col.AutoEditMode = DefaultableBoolean.False;
This kind of works, as the correct value gets saved to the database - but appears to have failed as the call shows 1234A
Regards,Jonathan
Hi again, sorry but it took me a long time to get to a position to try 22.2. I have now done so and the problem is persisting unfortunatley.
Thank you for your post. This looks like a bug to me. When you set autocomplete , and type value 123a it should not update to 123A , i believe it should give message that value not found or something . But also you are using version 19.1 so possibly issue is in this version only. Can you test and confirm if you can still reproduce the issue with latest 22.1/22.2 or share your sample i can test try to find the cause of the issue.
