380
Can't update Cell Value property
I'm having an odd problem where I can't update a cell's value.  Code like this:
 row.Cells["ID"].Value = newValue;
 doesn't work.  The value property doesn't change.  Even if I try to change the value in the VS debugger, it changes right back.  Did I accidentally set some sort of ReadOnly property for the cell.  This is a very odd problem as I've done this many times before without any problem.
 I'm trying to change the value in the InitializeRow event, where I usually do.  I've also tried changing the value after the grid has loaded and initialized, but that doesn't work either.
Jeff
