Hi all,
the UltraDropDown control, as I understand it, is usable in an UltraGrid and serves two purposes:
This works great if the foreign key is a single column, using ValueColumn, DisplayColumn, Datasource and DataMember.
But in my case, the key is composite. So, choosing an entry from the UltraDropdown would not set one single value in the affected row, but three of them. And, consequently, the meaning of the current FK value is not determined by a value in a single column. but by three columns. So, it's the combination of values that makes up the relation between master and detail table.
Is there any way to use the UltraDropdown here?
Thanks for any hint
Martin
