We recently upgraded our project from the v7.3 controls to the v8.2 controls. In the testing process, users are getting the error:
"Could not load file or assembly 'Infragistics2.Excel.v8.2, Version=8.2.20082.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified."
Our build process has always used the controls that are installed to C:\Program Files\Infragistics\NetAdvantage for...\Windows Forms\Bin, but it would appear that at least two dlls are no longer put there: Infragistics2.Documents.*.dll (which I don't think we use) and Infragistics2.Excel.*.dll.
Is this a permanent change and, if so, where should we grab these from in a Nant script for our build process now?
Ah, thanks. It seems odd to add a new directory for only two dll's, but that'll be easy enough to add to the build script. Thanks.
Check C:\Programme\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\Common
