Does Infragistics support Sunburst charts? I haven't found a way of being able to drill down into pie charts. I'd love to be able to chart like this:
https://www.highcharts.com/demo/sunburst
If not, is it on the roadmap?
Thank you for the update .Now i understand what you mean
Unfortunately we do not have anything yet planned. But you can create a new feature idea for future version
(or vote for existing ones) at < www.infragistics.com/.../>.
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
Thanks. That looks a pretty similar start point. But doesn't appear to have the drill-down functionality of the High Chart (e.g. if you click on one of the inner sections, it redraws the outer rings of the chart to filter just on this section.) This is a really cool feature, so I just wondered if it was on the roadmap for Infragistics?
Thank you for posting. I did little research and find Sunburst charts is looking same as DoughnutChart with multiple ring series.
In WinForm I don’t see any topic for the reference , although the gist should be something like this:
https://es.infragistics.com/products/ignite-ui-angular/angular/components/doughnut-chart#multiple-rings-demo
And you can find a sample ,if you have downloaded the winform sample browser then at WinDoughnutChart-> Disaplay->multiple Ring
