585
wincarousel show text along with image
Is it possible to show the image and some text. I wish to display some photographs of people along with their names underneath?
Thanks.
Dave
  • 7595
    Hello Dave,
    In WinCarousel ,to show test along with images you can refre to this online help document:
    www.infragistics.com/.../wincarousel-adding-carousel-items-in-code
    In order to have test underneath image , you can use text property,
    the text is confined within the bounds of the item/image. You can adjust the placement of the text within using the alignment properties in the Appearance, but it is always inside the item. We do not have any property to set it outside the image.
    Regards
