i am using the UltraRadialMenu with the actual Version 2020.2.
When a Tool ist clicked, i want to execute the drilldown and display the menu behind.If i do this manually by clicking with the mouse at the drilldown-button, everything is fine.The issue occurs on executing by code.
I am using the ToolClick-Event of the UltraRadialMenu.Private Sub UltraRadialMenu1_ToolClick(...) Handles UltraRadialMenu1.ToolClick
By PerformAction i want to do the drilldown.UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown)
Executing the PerformAction "DrillDown" doesn't do anything.UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown)
As mentioned in this post 5 years ago i tried to do the "NextItem" before.https://es.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/96474/radial-menu-performaction
UltraRadialMenu1.PerformAction(UltraRadialMenuAction.NextItem)UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown)Now i get different results on two Tools:at the first i have no reaktionat the second a drilldown is done - to a complete empty menu
By the way, if i do the drilldown with the mouse manually everything works.But executed by code doesn't work.
Here's the code:
Private Sub UltraRadialMenu1_ToolClick(sender As Object, e As Infragistics.Win.UltraWinRadialMenu.RadialMenuToolClickEventArgs) Handles UltraRadialMenu1.ToolClick Select Case e.Tool.Key Case "mnuNeueArbeit" UltraRadialMenu1.PerformAction(UltraRadialMenuAction.PreviousItem) UltraRadialMenu1.PerformAction(UltraRadialMenuAction.NextItem) UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown) Case "mnuFavoriten" UltraRadialMenu1.PerformAction(UltraRadialMenuAction.NextItem) UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown) End Select End Sub
A screenshot from the Readial-Menu
"Neue Arbeit" und "Favoriten" are the tools in request
The result after the click-event with "NextItem" and "Drilldown" at Favoriten, Click on "Neue Arbeit" has still no reaktion
If i click with the mouse at the drilldown-button of "Neue Arbeit" this menu is correctly shown.This should be the same result, when i click at the tool itself.
I have tried a lot of to get an other way around this bug - but i found nothing.
Do you have any idea?
Thanks a lot.
Greets,
Mike
Hi everyone,
i got a Mail from Infragistics Support
Paul wrote:
Hi Mike
This code works for me.
In _ToolClick put this code first before reading key. Remove your PreviousNext and NextItem in your Case Select. You will only need one DrillDown command. Hope this helps get you started.
For j = 0 To e.Tool.VisiblePosition 'Perform this amount of clicks Me.UltraRadialMenu1.PerformAction(UltraWinRadialMenu.UltraRadialMenuAction.NextItem)
Next
Me.ultraRadialMenu1.PerformAction(UltraWinRadialMenu.UltraRadialMenuAction.DrillDown)
Kind Regards Paul
Paul, thank you for your solution, it works fine.Here's my finally used code:
Private Sub UltraRadialMenu1_ToolClick(sender As Object, e As Infragistics.Win.UltraWinRadialMenu.RadialMenuToolClickEventArgs) Handles UltraRadialMenu1.ToolClick Select Case e.Tool.Key Case "mnuNeueArbeit" For j As Integer = 0 To e.Tool.VisiblePosition 'Perform this amount of clicks Me.UltraRadialMenu1.PerformAction(UltraWinRadialMenu.UltraRadialMenuAction.NextItem) Next UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown) Case "mnuFavoriten" For j As Integer = 0 To e.Tool.VisiblePosition 'Perform this amount of clicks Me.UltraRadialMenu1.PerformAction(UltraWinRadialMenu.UltraRadialMenuAction.NextItem) Next UltraRadialMenu1.PerformAction(UltraRadialMenuAction.DrillDown) End Select End Sub
Thanks again, Mike
