A drop down is created when you resize a screen such that all items of a toolbar can not fit. When I click on this drop down it seems i get more toolitems then just the ones belonging to the toolbar. I get all clipped toolbar items from every toolbar in the manager (at least I think thats what I am seeing). Is there a property to turn this feature off, so it only shows toolitems that belong to the toolbar.
Bill
This issue described in the first post was not the same as issue BR35680, which was fixed. The issue described is not a bug actually. This is correct functionality for most styles. The only way to prevent all bumped tools from a toolbar row from appearing in the overflow area is to set the UltraToolbarsManager.Style to Office2000.
We're currently using NetAdvantage 2008 Volume 2 (dll version 8.2.20082.2141) and problem still exists. Is it fixed in later versions?
(Also - is it possible to disable overflow and for several toolbars to behave as in flow layout. That is - if there are two or more toolbars and they do not fit, whole toolbar is moved lower)
I believe the current hotfix has the fix for this issue and has been released (8.2.20082.2022).
It's a bug that I have already reported (BR35680) but a solution is not available yet. (The same bug is visible in the Infragistics samples - i.e. the Infragistics Paint sample.)
