865
Can not build formula error - wingrid and ultracalcmanager
I have a grid and an ultracalmanager on the form. but when i try to set the formula for a column in design time, i get the error message "Cannot build formula without ultracalmanager.......".
the application environment is in VS 2008 and Infragistics 2008 vol2.
Can you please help?
kamal
  • 469350
    Verified Answer
     Hi Kamal,
    It sounds like somehow the grid didn't get hooked up to the CalcManager. This could indicate a problem with the CalcManager Designer on your machine.
    Try deleting and re-adding the CalcManager to the form and see if that helps.
    If not, go into the InitializeComponent method (in the Windows Forms Designer Generated Code)  and add a line like this to the section for the grid:
    this.ultraGrid1.CalcManager = this.ultraCalcManager1;
