I have a pretty standard grid with one column that I want to highlight words with bold and color.
i use a <b> tag and </b> tag on the text and set the style to ColumnStyle.FormattedText
I've used font and span tags to color, and removed them completely to see if that was the issue, it is not.
When it renders as you can see below it start of the bolded/colored text sometimes is rendered a little to the left and overwrites the text next to it.
Am I doing something wrong or is this a bug?
thanks
Jeff
setting the TextRenderingMode to GDI fixed the problem.
Hi Jeff,
There's nothing you should be able to do that should cause this. So it's almost certainly a bug. You should try updating the to latest Hot Fix. This might already be fixed. If that doesn't help, you should Submit an incident to Infragistics Developer Support.
If you want to try to work around this, you might try setting the TextRenderingMode property to GDI and see if that helps.
