80
ListView Group Divider
How can I change the default gradiant (blue to white) of the Group divider ?
  • 69832
    You can't change that color via the public object model...the following code sample demonstrates how to do it using the IUIElementCreationFilter interface:
    AppearanceData appearance = new AppearanceData();
    appearance.BackColor = Color.Red;
    appearance.BackColor2 = Color.Pink;
    this.listView.CreationFilter = new GroupDividerCreationFilter( appearance );
    #region GroupDividerCreationFilter
    /// <summary>
    /// IUIElementCreationFilter implementation which Handles the display of
    /// checkboxes for UltraListViewItems in Thumbnails mode.
    /// </summary>
    public class GroupDividerCreationFilter : IUIElementCreationFilter
        private AppearanceData appearance;
        /// <summary>
        /// Creates a new instance of the GroupDividerCreationFilter class.
        /// </summary>
        /// <param name="appearance">Defines the BackColor, BackColor2, and BackGradientStyle properties for the divider element.</param>
        public GroupDividerCreationFilter( AppearanceData appearance )
            this.appearance = appearance;
        #region IUIElementCreationFilter Members
        void IUIElementCreationFilter.AfterCreateChildElements(UIElement parent)
            if ( parent is UltraListViewGroupUIElement )
                UltraListViewGroupHeaderLineUIElement dividerElement =
                    parent.GetDescendant( typeof(UltraListViewGroupHeaderLineUIElement) )
                    as UltraListViewGroupHeaderLineUIElement;
                if ( dividerElement != null )
                    Rectangle rect = dividerElement.Rect;
                    UIElementsCollection childElements = parent.ChildElements;
                    childElements.Remove( dividerElement );
                    GroupDividerUIElement newElement = new GroupDividerUIElement(parent as UltraListViewGroupUIElement, this.appearance);
                    newElement.Rect = rect;
                    childElements.Add( newElement );
        bool IUIElementCreationFilter.BeforeCreateChildElements(UIElement parent)
            //  Return false to signify that the elements
            //  should be added as they normally are.
           return false;
        #endregion IUIElementCreationFilter Members
        #region GroupDividerUIElement class
        public class GroupDividerUIElement : UltraListViewGroupHeaderLineUIElement
            /// <summary>
            /// Creates a new instance of the GroupDividerUIElement class.
            /// </summary>
            public GroupDividerUIElement( UltraListViewGroupUIElement parent, AppearanceData appearance ) : base( parent )
            protected override void InitAppearance(ref AppearanceData appearance, ref AppearancePropFlags requestedProps)
                AppearanceData.Merge( ref appearance, ref this.appearance, ref requestedProps );
                base.InitAppearance(ref appearance, ref requestedProps);
        #endregion GroupDividerUIElement class
    #endregion GroupDividerCreationFilter
