20
UltraCalcManager without UI or references to Forms or Data
I would like to use UltraCalcManager in SQL Server as a CLR assembly. Currently UltraCalcManager references quite a few assemblies that are not supported in SQL CLR assemblies, such as Accessibility, System.Drawing, and System.Windows.Forms. I was able to create a prototype that appears to work, but I had to add 10+ assemblies and it would be much better if there was a "no UI" version.
I am using both the WinForms and WPF calc manager in other applications and I'd like to be able to provide the same calculation support from that database as well. I also created a REST web api for calculations using UltraCalcMan instead of UltraWebCalcMan but it would be better with a dedicated component (not based on System.Web.UI.Control). Also, it would be great to support .NET Core.
  • 1560
    Since the described functionality is currently not provided out of the box, I can suggest submitting a new product idea. You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com >.
    There are many benefits to submitting a product idea:
    -          Direct communication with our product management team regarding your product idea.
    -          Notifications whenever new information regarding your idea becomes available.
    -          Ability to vote on your favorite product ideas to let us know which ones are the most important to you.  You will have ten votes for this and can change which ideas you are voting for at any time.
    -          Allow you to shape the future of our products by requesting new controls and products altogether.
    -          You and other developers can discuss existing product ideas with members of our Product Management team.
    Steps to create your idea:
    1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
    2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
    3. Add your product idea and be sure to be specific and provide as much detail as possible.
    The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Thank you for contacting Infragistics.
    Teodosia Hristodorova
    Associate Software Developer
