1660
How to increase header height in Ultragrid ?
Scenario 1:
I have an ultragrid in my application as shown below.
I have increased the row height. Please refer the screen shot.
400
Scenario 2:
I have modified the same grid by increasing header height by setting the property colheaderlines to 2. Please refer the image given below.
What I would like to have is, instead of setting colheaderlines, I would like to set height in pixels or points.
Could someone help in finding a solution for this ?
It would be great, if solution is given as a sample project.
Thanks.
Parents
No Data
Reply
  • 469350
    As mentioned, the only way to set the header height to a specific pixel value is to use RowLayouts. To achieve that, you would do something like this:
            private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
                var layout = e.Layout;
                var band = layout.Bands[0];
                var ov = layout.Override;
                band.RowLayoutStyle = RowLayoutStyle.ColumnLayout;
                // Assuming that none of the other columns PreferredLabelSize is set
                // you can simply set the height of one of them to affect all headers
                // in the band.
                band.Columns[0].RowLayoutColumnInfo.PreferredLabelSize = new Size(0, 100);
    This might be a good solution for you, but you should be aware that using RowLayouts will carry with it certain changes to how the grid looks (you might notice a different in spacing or padding of cells) And also and certain limitations - using RowLayots this will disable Fixed (column) Headers, as fixed headers and RowLayouts are mutually exclusive. If you are not using Fixed Headers, anyway, then this is probably a good way to go.
Children
No Data
