I'm trying to use a Ribbon with the ApplicationMenu2010 for the first time. I set it up using the designer and everything looks fine. The backstage opens, I can properly see the back button and the areas where I add tabs or buttons.
Now I and hide the QAT by setting the QuickAccessToolbar.Visible property to false. The QAT hides, the caption area disappears. All as expected. When I select the "File" tab, now the backstage left buttons area covers most of the Back button. With no tools yet added, the "Insert new tool" item is covering the back button. Is there a way to control the location of the backstage left buttons area when it opens? Is this a bug?
Hello Tom,
Thank you for the update. I have logged this for further investigation with the ID 268279. I have also create a private case where I will provide you with more details.
Hi Michael,
Here are answers to your questions.
ribbonbug.XML
Tom
What version are you using?
16.2 Are you seeing this in design mode or when running the application?
Both
Are you in a high DPI environment?
No. I see this in multiple environments I’ve tried
Do you have a sample you can attach?
I’m writing using the Progress language. You license these controls to them, and it’s through them I purchased. So it’s not easy to attach something you can use. It is, however, remarkably easy to duplicate. I've listed steps to duplicate below. I don’t see any similar problem using the 2007 style application menu. I have attached a configuration file I exported from the non-working sample.
Here are the exact steps to duplicate
That’s enough to show the problem. I can switch between it looking correct and faulty with the QAT visible setting. FormDisplayStyle is also involved as when I don’t set it to Standard, things look OK.
Thank you for contacting Infragistics Developer Support!
I have some questions concerning this matter:
What version are you using?Are you seeing this in design mode or when running the application?Are you in a high DPI environment?Do you have a sample you can attach?
