I'm trying to upgrade a WinForms solution from v10.3 to 2018.2, one of whose Projects includes the following references:
Infragistics.Practices.CompositeUI.WinForms
Infragitics2.Shared.v10.3
Infragistics2.Win.UltraWinDock.v10.3
Infragistics2.Win,UltraWinGrid.v1.3
Microsoft.Practices.CompositeUI
Microsoft.Practices.CompositeUI.WinForms
Microsoft.PRactices,ObjectBuilder
System
System.Core
System.Drawing
System.WindowsForms
The utility tool gives an error "Can't find a newer version for assembly Infragistics.Practices.CompositeUI.WinForms"
Because of this while building my project I get an error
Error 2 The type 'Infragistics.Win.UltraWinDock.UltraDockManager' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics2.Win.UltraWinDock.v10.3, Version=10.3.20103.2145, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. C:\Projects\MyProject\ApplicationTechnicalServices\UI Services\CABExtensions\CustomWorkspaces\DockingWorkspace.cs 423 11 CABExtensions
Where is the new version of Infragistics.Practices.CompositeUI.WinForms, please?
I believe there are no new mappings for these assemblies. In case you need them. you need to build them as per the guide linked. Then again, this is from 2007, so no guarantees it will work.
I'd advise, if possible, to try to migrate your app to the new components available from our SDK.
Sincerely,Tihomir TonevAssociate Software DeveloperInfragistics
So, mappings are:
Infragistics.Practices.CompositeUI.WinForms.UltraDockWorkspace => Infragistics.Win.UltraWinDock.UltraDockManager
Microsoft.Practices.CompositeUI.WinForms.DeckWorkspace => ?
Infragistics.Practices.CompositeUI.WinForms.UltraDockSmartPartInfo => ?
While it is not the same, UltraDockManager is a similar control, which may prove the be a good alternative. For a full list of components coming with our current winforms SDK, please visit our website here.
Should you have any further questions, please let me know.
One last question, if you don't mind: I understand it's deprecated, but are there any alternatives to UltraDockWorkspace that are inbuilt to Infragistics_DevTools_20182.exe?
Yes, after you complete the installation you should have such a file locally on your machine.
