105
UltraComboEditor Text not updating
I have an UltraComboEditor where I am dynamically setting the Items that appear in the drop-down depending on the actions of a user.
It has the ChecBoxStyle set to CheckBox and EditorValueSource set to CheckedItems.
I am pre-populating the items with a single item which is correctly being displayed.
When I then select to add a new item to the control it is correctly being added to the items and when I drop down the control it appears in the available list and is correctly checked, but the display of the data in the control when closed does not change, I am wanting both items to be displayed in the control like Item1; Item2.  No mater what I do, all I get is Item1 displayed.
What do I have to do in order to get the display to correctly display all the items that are checked in the list?
Regards
Sean
