I'm filling UltraGrid with a DataTable. When I try to filter, it gives an error that DBNull can't be converted to other types. Is there a way to handle this at the grid-level w/o having to check every single col and every single row?
I've got a lot of cols and a lot of rows so it would be a lot of code and would probably slow it down too much.
Cool. Glad you got it solved. :)
It's probably not immediately obvious that the events like AfterCellUpdate fire not just for normal data cells, but also for the filter cells. It's something to keep in mind when handling any of the cell or row events in the grid.
YEP, THAT FIXED IT!
I was trying to find that IsFilterRow property but didn't hit the right combo.
Aha! AfterCellUpdate does not fire on every keystroke. It fires whenever the cell is committed to the underlying data source. For a normal data cell, that happens when the grid loses focus or you leave the cell. But for the FilterCell, it's probably happening on every keystroke so that the filter gets updated as you type.
This is very easy to solve. Keep using the AfterCellUpdate event. But whatever you are doing in that event, you don't need to do it for the FilterCell, which is not part of the data, anyway.
So all you have to do is check, at the top of AfterCellUpdate, if grid.ActiveCell.Row.IsFilterRow and if so, bail out.
Ok now we're getting somewhere. I allow for updating a single col in the AfterCellUpdate event. It's calling that event after every keystroke, which isn't what I want. I only want it to update when I leave the cell. Ok, I can choose a new event.
The question is though, how do I make it know the difference between the filter row and a data row so that the event won't fire for the filter row?
Okay, that's not an exception, that's a message that is bubbled up from the grid's events.
Just to clarify, from the screen shot, it looks like you are filtering by a value of "2014", so you are not trying to filter by a null value. Is that correct?
The weird thing is that this message seems to indicate that the grid is trying to save a value to the underlying data source - which doesn't make sense. There's no reason why the grid should be updating the data in the middle of a filtering operation. Unless maybe something in your code is doing that. Like maybe you are handing some event of the grid that is getting fired and doing something in your code that is trying to modify the data while in the middle of a filtering operation.
Try trapping the grid's CellDataError and Error events and put breakpoint in there and see if either of those events is getting fired when this message comes up. If so, post the call stack here so we can see why the event got fired.
