I'm setting a BindingSource to CalendarInfo.DataBindingsForAppointments for UltraDayView, and the control only displays the first item in the BindingSource. The setting is supposed to be easy, but I cannot figure out why I'm having this issue. My code looks like the following.
Private mTaskList As New EntityList(Of Task) Public mTaskBS As New BindingSource mTaskBS.DataSource = mTaskList mTaskList.ReplaceRange(mPerManager.GetEntities(Of Task)) 'Using Ideablade.PersistenceManager. The function returns EntityList
UltraCalendarInfo1.DataBindingsForAppointments.SetDataBinding(mTaskBS, "Task") UltraCalendarInfo1.DataBindingsForAppointments.BindingContextControl = Me
UltraCalendarInfo1.DataBindingsForAppointments.SubjectMember = "Subject" UltraCalendarInfo1.DataBindingsForAppointments.StartDateTimeMember = "StartDate" UltraCalendarInfo1.DataBindingsForAppointments.EndDateTimeMember = "DueDate"
uvDay.CalendarInfo = UltraCalendarInfo1 uvWeek.CalendarInfo = UltraCalendarInfo1 uvMonthSingle.CalendarInfo = UltraCalendarInfo1 uvMonthMulti.CalendarInfo = UltraCalendarInfo1 uvShared.CalendarInfo = UltraCalendarInfo1
I am wonderinf it it is just how I set the DataBindingsForAppointments, or that I am using the 3rd party product to set the BindingSource's DataSource. Please let me know if you have any idea.
Thanks.
Hello Aaron,
I got it work! Thanks for your advice!!!
Megumi
Try putting your "SetDataBindings" call at the end of your code block.
Like such:
If this still doesn't work then investigate your binding source... bind it to a datagrid and check out the contents.
You can also try: UltraCalendarInfo1.DataBindingsForAppointments.RefreshData()
This will try to synchronize your control to the datasource.
CheersAaron
