Is there a way to set up the UltraGrid so that when you click on a row in a grid, it's data is copied to the AddRow for editting? Our users would like to edit on one line as opposed to edtting in grid. I can think of a few workarounds, but if Infragistics could handle this out of the box, it would be a big help.
Thanks!
-Lee
Hi Lee,
I'm afraid I don't understand your question. If you click on a row in the grid, then that row becomes the active row. What does that have to do with adding a row? Do you mean you want some sort of context menu or a button where the user can copy an existing row into a new row and then edit it? There's nothing built-in to the grid for that.
