Is it possible to limit the horizontal scrolling on a UltraGanttChart?
Anytime I get to the left or right side of the scrollbar it then extends to provide a new region, which ends up as infinite scrolling.
I came searched how to do this but couldn't find anything but this 3 year old post who states at that time it wasn't possible:
https://es.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/89794/ultraganttview---set-horizontal-scroll-bar-range-to-correspond-to-the-project-duration
We are using version 16.1
Hello Serge,
Thank you for following up. The UltraGanttControl is intended to resemble MS Project from the time it was created. The last feature for the UltraGantt was touch-enabled support in late 2013. You can submit a new product idea on our new page at <https://es.infragistics.com/community/ideas>.
Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
Thank you in advance to submitting your product idea.
