510
Ultradock and split container.
Basically I need a form that divided into two halves with a horizontal split. The top panel will be divided in to two dockable group boxes with a vertical split between them. However, the vertical split should only split the top panel. The bottom panel will have 3 dockable group boxes. 2 of them will have ultratab controls inside of them. I also need vertical split between each of dockable group boxes in the bottom panel that only splits the bottom panel.
The group boxes will only be able to be docked to its original panel. Controls in the top panel can’t be docked to the bottom panel and controls in the bottom panel can’t be docked to the top panel.
