470
Reserve some deleting rows failure
In the fuction, the event argument e is changed, but the rows i want to reserve are still deleted by the ultragrid.
        protected override void OnBeforeRowsDeleted(BeforeRowsDeletedEventArgs e)
            if (MsgHelper.Confirm("是否确定删除选中的行?"))
                List<UltraGridRow> listRow = new List<UltraGridRow>();
                for (int i = e.Rows.Length - 1; i >= 0; i--)
                    if (e.Rows[i].IsAddRow) continue;
                    Details detail = e.Rows[i].ListObject as Details;
                    if (detail.Id != 0)                                         // Some details.Id aren't equal to 0
                        e.Rows[i].Hidden = true;
                        detail.Deleted = true;
                    else
                        listRow.Add(e.Rows[i]);
                e = new BeforeRowsDeletedEventArgs(listRow.ToArray(), false);
                MsgHelper.Info("数据已删除成功.");
            else
                MsgHelper.Info("操作已取消.");
                e.Cancel = true;
            base.OnBeforeRowsDeleted(e);
  • 469350
    Setting e to a new instance will not work. I think what you have to either modify e.Rows, or if that doesn't work, you would have to set e.Cancel to true and delete the rows you want while leaving the others alone.
