60
Newly Added Row Vanishes From Hierarchical WinGrid
We are using an UltraWinGrid, in hierarchical mode, and are binding it to an XML file.  When I add a new row, if this row happens to be the first row in the band, the row immediately vanishes from the grid upon saving the data.
 The grid is bound to a DataSet object.  And, this is within the .NET 2.0 framework.  The code is reasonably simple: we do a ReadFromSchema() to get the schema from the .xsd file, then a ReadFromXML() to load the data.  Saving is the reverse: WriteToXML().
Has anyone else seen this problem?
Benjamin
  • 469350
    Verified Answer
    Hi Benjamin.
    Can you be more specific? How exactly are you adding a new row? What are you adding it to? Does it show up in the grid initially?
