1075
Exception while scrolling right
I have grid with column chooser at left. When I try to scroll to the right at the end of the grid I receive a memory error. Also scrollbar is in the middle position when the last column shows. How to fix this?
I use the following code for Initializing Layout:
private void gridViewWaste_InitializeLayout(object sender, InitializeLayoutEventArgs e)
if ((configfileName != null) && (!configfileName.Equals("")))
try
this.gridViewWaste.DisplayLayout.LoadFromXml(configfileName);
SetFilterLabel();
catch (Exception)//don't show exception if we were not able to load
MessageBox.Show("Config file is not correct. Applying default settings", "VWA View Waste Config");
// disable key fields for editing
e.Layout.Bands["Weights"].Columns["ID"].CellActivation = Activation.Disabled;
e.Layout.Bands["Weights"].Columns["TransKey"].CellActivation = Activation.Disabled;
e.Layout.Bands["Weights"].Columns["WasteCost"].CellActivation = Activation.Disabled;
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["Weight"].Style =
Infragistics.Win.UltraWinGrid.ColumnStyle.Double;
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["WasteCost"].Style =
Infragistics.Win.UltraWinGrid.ColumnStyle.CurrencyNonNegative;
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["FoodTypeCost"].Style =
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["ContainerWeight"].Style =
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["ContainerCost"].Style =
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["NItems"].Style =
Infragistics.Win.UltraWinGrid.ColumnStyle.IntegerPositiveWithSpin;
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["NProduced"].Style =
Infragistics.Win.UltraWinGrid.ColumnStyle.IntegerNonNegativeWithSpin;
// Hide the irrelevant columns
//e.Layout.Bands["Transfers"].Columns["TransKey"].Hidden = true;
// Resize the columns that we are interested in
e.Layout.Bands["Weights"].Columns["Timestamp"].Width = 150;
e.Layout.Bands["Weights"].Columns["IsPreconsumer"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["PreconsumerNames"];
e.Layout.Bands["Weights"].Columns["FoodTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["FoodNames"];
e.Layout.Bands["Weights"].Columns["LossTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["LossNames"];
e.Layout.Bands["Weights"].Columns["ContainerTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["ContainerNames"];
e.Layout.Bands["Weights"].Columns["StationTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["StationNames"];
e.Layout.Bands["Weights"].Columns["DispositionTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["DispositionNames"];
e.Layout.Bands["Weights"].Columns["DaypartTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["DaypartNames"];
e.Layout.Bands["Weights"].Columns["BEOTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["BEONames"];
e.Layout.Bands["Weights"].Columns["UserTypeID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["UserNames"];
e.Layout.Bands["Weights"].Columns["UOMID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["UOMNames"];
this.gridViewWaste.DisplayLayout.Bands["Weights"].Columns["FoodTypeID"].Style =
Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownValidate;
// Make the style of these two columns Edit so that the value list dropdown arrow
// doesn't appear, since we are displaying a custom edit control rather than use the
// ValueList
//e.Layout.Bands["Transfers"].Columns["FoodTypeID"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Edit;
// We don't want to see the time portion of the date in the
// date columns, and we don't want to see the date portion
// in the time columns, so let's use the column's Format property
// to filter out the portions of the DateTime object that we don't want
e.Layout.Bands["Weights"].Columns["Timestamp"].Format = "MM/dd/yyyy hh:mm:ss";
// init colum headers
e.Layout.Bands["Weights"].Columns["TransKey"].Header.Caption = "Transfer Key";
e.Layout.Bands["Weights"].Columns["WasteCost"].Header.Caption = "Waste Cost";
e.Layout.Bands["Weights"].Columns["FoodTypeID"].Header.Caption = "Food Type";
e.Layout.Bands["Weights"].Columns["FoodTypeCost"].Header.Caption = "Food Type Cost";
e.Layout.Bands["Weights"].Columns["LossTypeID"].Header.Caption = "Loss Type";
e.Layout.Bands["Weights"].Columns["ContainerTypeID"].Header.Caption = "Container Type";
e.Layout.Bands["Weights"].Columns["ContainerWeight"].Header.Caption = "Container Weight";
e.Layout.Bands["Weights"].Columns["ContainerCost"].Header.Caption = "Container Cost";
e.Layout.Bands["Weights"].Columns["StationTypeID"].Header.Caption = "Station Type";
e.Layout.Bands["Weights"].Columns["DispositionTypeID"].Header.Caption = "Disposition Type";
e.Layout.Bands["Weights"].Columns["DaypartTypeID"].Header.Caption = "DayPart Type";
e.Layout.Bands["Weights"].Columns["BEOTypeID"].Header.Caption = "Event Order Type";
e.Layout.Bands["Weights"].Columns["UserTypeID"].Header.Caption = "User Type";
e.Layout.Bands["Weights"].Columns["UserQuestion"].Header.Caption = "User Question";
e.Layout.Bands["Weights"].Columns["NItems"].Header.Caption = "Number of Items";
e.Layout.Bands["Weights"].Columns["NProduced"].Header.Caption = "Number of Produced Items";
e.Layout.Bands["Weights"].Columns["UOMID"].Header.Caption = "Unit of Mesure";
// You can control the appearance of the separator using the SpecialRowSeparatorAppearance
// property.
e.Layout.Override.SpecialRowSeparatorAppearance.BackColor = Color.FromArgb(233, 242, 199);
e.Layout.Override.RowAppearance.BackColorAlpha = Infragistics.Win.Alpha.Transparent;
// use the same appearance for alternate rows
e.Layout.Override.RowAlternateAppearance = e.Layout.Override.RowAppearance;
e.Layout.Override.CellAppearance.BackColorAlpha = Infragistics.Win.
Alpha.UseAlphaLevel;
e.Layout.Override.CellAppearance.AlphaLevel = 150;
e.Layout.Override.HeaderAppearance.AlphaLevel = 150;
e.Layout.Override.HeaderAppearance.BackColorAlpha = Infragistics.Win.
// FILTER ROW FUNCTIONALITY RELATED ULTRAGRID SETTINGS
// Enable the the filter row user interface by setting the FilterUIType to FilterRow.
e.Layout.Override.FilterUIType = FilterUIType.FilterRow;
// FilterEvaluationTrigger specifies when UltraGrid applies the filter criteria typed
// into a filter row. Default is OnCellValueChange which will cause the UltraGrid to
// re-filter the data as soon as the user modifies the value of a filter cell.
e.Layout.Override.FilterEvaluationTrigger = FilterEvaluationTrigger.OnCellValueChange;
// By default the UltraGrid selects the type of the filter operand editor based on
// the column's DataType. For DateTime and boolean columns it uses the column's editors.
// For other column types it uses the Combo. You can explicitly specify the operand
// editor style by setting the FilterOperandStyle on the override or the individual
// columns.
//e.Layout.Override.FilterOperandStyle = FilterOperandStyle.Combo;
// By default UltraGrid displays user interface for selecting the filter operator.
// You can set the FilterOperatorLocation to hide this user interface. This
// property is available on column as well so it can be controlled on a per column
// basis. Default is WithOperand. This property is exposed off the column as well.
e.Layout.Override.FilterOperatorLocation = FilterOperatorLocation.WithOperand;
// By default the UltraGrid uses StartsWith as the filter operator. You use
// the FilterOperatorDefaultValue property to specify a different filter operator
// to use. This is the default or the initial filter operator value of the cells
// in filter row. If filter operator user interface is enabled (FilterOperatorLocation
// is not set to None) then that ui will be initialized to the value of this
// property. The user can then change the operator as he/she chooses via the operator
// drop down.
e.Layout.Override.FilterOperatorDefaultValue = FilterOperatorDefaultValue.Equals;
// FilterOperatorDropDownItems property can be used to control the options provided
// to the user for selecting the filter operator. By default UltraGrid bases
// what operator options to provide on the column's data type. This property is
// avaibale on the column as well.
e.Layout.Override.FilterOperatorDropDownItems = FilterOperatorDropDownItems.Default;
// By default UltraGrid displays a clear button in each cell of the filter row
// as well as in the row selector of the filter row. When the user clicks this
// button the associated filter criteria is cleared. You can use the
// FilterClearButtonLocation property to control if and where the filter clear
// buttons are displayed.
e.Layout.Override.FilterClearButtonLocation = FilterClearButtonLocation.RowAndCell;
// Appearance of the filter row can be controlled using the FilterRowAppearance proeprty.
e.Layout.Override.FilterRowAppearance.BackColor = Color.LightYellow;
// You can use the FilterRowPrompt to display a prompt in the filter row. By default
// UltraGrid does not display any prompt in the filter row.
e.Layout.Override.FilterRowPrompt = "Click here to filter data...";
// You can use the FilterRowPromptAppearance to change the appearance of the prompt.
// By default the prompt is transparent and uses the same fore color as the filter row.
// You can make it non-transparent by setting the appearance' BackColorAlpha property
// or by setting the BackColor to a desired value.
e.Layout.Override.FilterRowPromptAppearance.BackColorAlpha = Alpha.Opaque;
// for smart datetime filters
e.Layout.Bands["Weights"].Columns["Timestamp"].FilterOperandStyle = FilterOperandStyle.DropDownList;
e.Layout.Bands["Weights"].Columns["Timestamp"].FilterOperatorLocation = FilterOperatorLocation.Hidden;
// By default the prompt is spread across multiple cells if it's bigger than the
// first cell. You can confine the prompt to a particular cell by setting the
// SpecialRowPromptField property off the band to the key of a column.
//e.Layout.Bands["Weights"].SpecialRowPromptField = e.Layout.Bands["Weights"].Columns[0].Key;
// Display a separator between the filter row other rows. SpecialRowSeparator property
// can be used to display separators between various 'special' rows, including for the
// filter row. This property is a flagged enum property so it can take multiple values.
e.Layout.Override.SpecialRowSeparator = SpecialRowSeparator.FilterRow;
//e.Layout.Override.AllowAddNew = AllowAddNew.FixedAddRowOnBottom;
e.Layout.Override.AllowDelete = DefaultableBoolean.True;
e.Layout.Override.AllowUpdate = DefaultableBoolean.True;
// sorting properties
e.Layout.Override.HeaderClickAction = Infragistics.Win.UltraWinGrid.HeaderClickAction.SortMulti;
// display cell text on multiple lines
e.Layout.Override.RowSizing = RowSizing.AutoFree;
e.Layout.Override.CellMultiLine = DefaultableBoolean.True;
// turn row selectors on for band 0
e.Layout.Bands["Weights"].Override.RowSelectors = DefaultableBoolean.True;
// init transfer's bands if used
if (e.Layout.Bands[0].Key.Equals("Transfers"))
e.Layout.Bands[
"Transfers"].Columns["TransKey"].CellActivation = Activation.Disabled;
//value editors
Infragistics.Win.UltraWinMaskedEdit.UltraMaskedEdit editor = new Infragistics.Win.UltraWinMaskedEdit.UltraMaskedEdit();
editor.EditAs = Infragistics.Win.UltraWinMaskedEdit.EditAsType.UseSpecifiedMask;
editor.InputMask = @"4\.nn\.nn";
editor.DataMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeLiterals;
editor.ClipMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeLiterals;
editor.DisplayMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeLiterals;
e.Layout.Bands["Transfers"].Columns["TrackerSWVersion"].EditorControl = editor;
// Set the mask modes. This only effects columns that use EditorWithMask or derived editors.
e.Layout.Bands["Transfers"].Columns["TrackerSWVersion"].MaskDisplayMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeBoth;
e.Layout.Bands["Transfers"].Columns["Timestamp"].Width = 150;
e.Layout.Bands["Transfers"].Columns["Timestamp"].Format = "MM/dd/yyyy hh:mm:ss";
// The FoodTypeID and LossTypeID
// columns should display the name, not the ID.
// We can use a ValueList to accomplish this
e.Layout.Bands["Transfers"].Columns["TermID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["TermNames"];
e.Layout.Bands["Transfers"].Columns["SiteID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["SiteNames"];
e.Layout.Bands["Transfers"].Columns["TypeCatalogID"].ValueList = this.gridViewWaste.DisplayLayout.ValueLists["TypeCatalogNames"];
e.Layout.Bands["Transfers"].Override.RowSelectors = DefaultableBoolean.True;
e.Layout.Bands["Transfers"].Columns["Timestamp"].FilterOperandStyle = FilterOperandStyle.DropDownList;e.Layout.Bands["Transfers"].Columns["Timestamp"].FilterOperatorLocation = FilterOperatorLocation.Hidden;
