260
How do I decode a layout byte array without loading it into a gird?
I save layouts to a stream using:
  grid.DisplayLayout.Save(stream, flags);
which I save to the database as a byte array.
Then, when I want to load the layout, I use:
  grid.DisplayLayout.Load(stream);
So far so good.
The problem I am having is that I need to know what columns a user has displayed, but without loading the layout into a grid (basically business logic related to visible grid columns is in an area of the application that does not have a grid displayed, not does it make sense to display one).
When I try to decode the layout byte stream:
  Encoding.Default.GetString(layoutByteArray);
The data is not easy to decipher, below is a snippet:
I notice that it contains null terminators, control codes, and other odd characters.
Is there a way to decode this?
