Hello everybody,
I am facing some issues with UltraDockManager SaveAsXML and LoadFromXML methods.
I am using these methods to save and load the layout of my dock areas and panels. However, I am havning problems when I set a language with different charcater set, e.g. Italian, Hindi, Russian
For instance, If I set Italian and I have a dockPanel test like Proprietà , when I save the xml and then load again the xml the next time the text will be "Propriet?"
How can I fix this? Is there a way to set the encoding? What about other languages?
Thanks in advance for your help
Valentina
Hello Valentina,
Thank you for your update. I am glad that you were able to resolve the issue you were seeing with the encoding of the UltraDockManager.SaveAsXML and LoadFromXML method.
In the meantime, I had put together a sample project in an attempt to reproduce the behavior you are seeing, but I am currently unable to reproduce it on my end when running against version 17.1.20171.2032 of the Infragistics for Windows Forms 2017.1 assemblies. For reference, I will be attaching this sample project here.
Sincerely,AndrewAssociate Developer
Nevermind, found the encoding issue in my code.
