160
ItemClick fires twice
I am using the UltraWinExplorerBar which is wrapped within a UserControl.  I have set this UserControl in a new form.  I have also set the UseMnemonics on the menu items to 'true'.  When I hot key to a menu item the ItemClick event fires twice.  I would suspect that this is a bug, since I have reproduced this with a very simple sample project.
Randall Luce
  • 69832
    Note that this is a peer-to-peer forum, and is not intended to be used for reporting bugs. I was unable to reproduce the issue you described here with a simple test, so you should report the issue and include the test project with which you are able to reproduce it.
