305
Ultragrid does not get populated on the server
I am working on a .net based windows application. I have an ultragrid, which has been coded to be populate (corresponding to a particular check) in a tab activation. The thing is, that the functionality is working fine while debugging/running the code in local machine. However, once the same code is deployed on the server, we are trying to test this functionality after installing the deployed application but the grid doesn't get populated for the same record.
We have double checked the data/code, there was no issue in deployment as well, since all the other functionalities were working fine. Are you able to think of a reason for such anomaly?
