How can I turn off the current row (arrow head) and new row indicators (asterisk/star) in the Row Headers?
I'm probably too late on this, but it turns out that there is a way to hide the images:
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Override.RowSelectorAppearance.ImageAlpha = Alpha.Transparent; }
There's no property to hide the indicators without hiding the row selectors. You could probably acheive what you want using a DrawFilter, though.
When I tried it, it does not turn off the indicators alone. Instead it completely hides the row headers. I want the row headers, I just do not want the graphic indicators.
Hi seradex,
Set this prop,
grd.DisplayLayout.Override.RowSelectors = DefaultableBoolean.False
to Turn off the row header indicators
hppy Kodin,
Arun
