I am adding an UltraCombo editor to a cell grid at run time in the initialize layout event. That all works as advertised and I can get my values from the drop down or add a new entry when I need to. However, I also need to have an editorbutton on the embedded combobox, also added at runtime. When I hook that up in the initililizeLayout event on the grid the button does not show up in the combo editor. However, if I move the initialization of the combobox and the button to the InitializeRow event it all works.
My question is why does the InitilizeLayout event not allow for the combo box button to be added but the same code works in the initializerow event.
I am including a simplified version of the code
Dim ucDropDown As New Infragistics.Win.UltraWinGrid.UltraCombo
Dim utbtnTemp As New Infragistics.Win.UltraWinEditors.EditorButton
ucDropDown.DataSource = SomeDataTable
ucDropDown.ValueMember = "ValueField"
ucDropDown.DisplayMember = "MemberField"
utbtnTemp = New Infragistics.Win.UltraWinEditors.EditorButton With {
.Key = "Column123",
.Text = "..."}
ucDropDown.ButtonsLeft.Add(utbtnTemp)
AddHandler ucDropDown.EditorButtonClick, AddressOf ucDropDown_EditorButtonClick
ucDropDown.DropDownButtonDisplayStyle = Infragistics.Win.ButtonDisplayStyle.Always
e.Row.Band.Columns("Some Col Name").EditorComponent = ucDropDown
e.Row.Band.Columns("Some Col Name").AutoCompleteMode = AutoCompleteMode.SuggestAppend
e.Row.Band.Columns("Some Col Name").Style = ColumnStyle.DropDown
e.Row.Band.Columns("Some Col Name").ButtonDisplayStyle = UltraWinGrid.ButtonDisplayStyle.Always
ucDropDown.MaxDropDownItems = 12
Jannik
Hi Milko,
Not sure why my initial solution did not work. The only thing I can think of was that I simplified the code I sent you from my original code and I suspect I was making the changes to the underlying Combobox table instead of the grid the combobox was applied to.
In any case, thanks for your prompt reply and showing me that the solutions was working as expected. Next time, I will do an actual little project like you did to prove my concept.
Hello Jannik,
I followed the steps you suggested and was unable to reproduce the behavior you're describing. I’ve created a small sample with an UltraGrid. I added UltraCombo as EditorComponent, as you did, in InitializeLayout event. When I start my sample the editor button is visible and functional.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this issue.
If the project does not work correctly, this indicates either an issue possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using Infragistics for Windows Forms 2017 volume 1. Therefore, could you please let me know the exact version of Infragistics components which you are using?
If the project does show the product feature working correctly, this indicates a possible issue in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back.
Please let me know if I can provide any further assistance.
