790
Option Set formatting
I have a requirement for a grid containing two columns...an answer in the form of radio buttons, and a question that can be long and often needs to be wrapped onto more than one line.  When I enable row sizing, both the answers and the questions format with multiple lines...even if I set CellMultiLine to False on the question and True on the answer.  Is there a way to force the questions to remain on one line? I will attach a modified version of the radio button demo app I found elsewhere on the forum to demonstrate the issue.
Darin
UltraGridWithRadioButtons96866.zip
  • 6120
    Hello Darin,
    After investigating for a way to set CellMultiline to false for one column and true for another when RowSizing is enabled and doing some research,  this has been determined to be a product idea. You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
    Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. You can also link back to this thread for additional details.
    Thank you in advance to submitting your product idea.
    Sincerely,
    Sahaja Kokkalagadda
    Associate Software Developer
