230
Context menu not working for the grid cell with custom editor
I use UltraControlContainerEditor to build custom date time editor for the grid. I create a menu in ultraToolbarsManager1 then set the context menu for the grid.
this.ultraToolbarsManager1.SetContextMenuUltra(this.grid, "GridPopUpMenu");
The "GridPopUpMenu" shows correctly when the cell is in display mode. However, when it is in Edit Mode, the "GridPopUpMenu" does not show. It just show the normal context menu for a text box.
Do we have anyway to fix this?
  • 960
    Verified Answer
    Hello Kim,
    I've investigated your issue that context menu does not pop up on cells which use UltraControlContainerEditor when they are in edit mode.
    In order to achieve what you want to do, you could assign the same context menu to the editor you use when those cells are in edit mode. For example, if you use .NET DateTimePicker as EditingControl of UltraControlContainerEditor, you could specify the context menu for the DateTimePicker's instance, like this:
        ultraToolbarsManager1.SetContextMenuUltra(dateTimePicker1, "GridPopUpMenu");
    I attached a sample application. In the sample application, I put a DateTimePicker and an UltraGrid on the form and specify an editor which inherits UltraControlContainerEditor for grid's "Date" column's editor. The editor itself uses the DateTimePicker instance as EditingControl. And I call the above method in the form's load event.
    I hope this will help you.
    Best Regards,
    Noriko I.
    Developer Support Engineer
    Infragistics, Inc.
    WindowsFormsApplication2.zip
