I want to customise the resources in the UltraWinGrid....
I have a project where i reference the WPF and WIN Infragistics DLLs
when i use the resourceCustomizer i have an ERROR :: check the attached image.
Hello Michel,
This error happens when you have two versions of a DLL that use the same namespaces and class names. You can use external assembly alias to wrap the namespaces from each assembly inside root-level namespaces, which enables them to be used in the same file. So, first you have to specify the ‘Aliases’ property of the .dll references in the following way:
1. In Visual Studio Solution Explorer, open References folder2. Select Infragistics4.Shared.v16.2 reference and right-click on it, select ‘Properties’3. Enter alias value in "Aliases" property, for example ‘WinForms’ 4. Select InfragisticsWPF4.v16.2 reference and right-click on it, select ‘Properties’5. Enter alias value in "Aliases" property, for example ‘WPF’
To use the aliases from within a program, reference them by using the extern keyword. Note that the extern aliases should be placed on top of all usings:
extern alias WinForms; extern alias WPF; using System.Windows.Forms; ...
extern alias WPF;
Then, in code you specify the alias namespace and class you would like to use the following way:
WinForms.Infragistics.Shared.ResourceCustomizer rc;WPF.Infragistics.Shared.ResourceCustomizer rc1;
In your case, I guess you would need only the WinForms ResourceCustomizer rc as you are using the WinForms UltraGrid.
