1350
Disable hot tracking for certain ribbon tabs
Hi all,
I try to "disable" some ribbon tabs under certain conditions, e.g. the user is in a special mode, then he can no longer use Ribbon Tab-3 and Ribbon Tab-5. However these tabs should remain visible. I managed this by placing a boolean value (enabled = true/false) in the tabs Tag property and handling the event BeforeRibbonTabSelected.So the user can no longer select those tabs.
So far so good! Now I want to disable also the hot tracking for those "disabled" tabs and change the caption text of those tabs to a somehow disabled appearance.
How can can I do this ? Any ideas? DrawFilter?
Thanks! Regards
Michael
