595
Question about UltraGrid
I have a question about UltraGrid. When splitting rows scroll region in a grid for more then one, can each region have different DataSource? Or all regions using the same data source that was set by:
ultraGrid1.DataSource = myBindingSource.
Thanks.
  • 7695
    Hi Ziv,
       No you cannot have differing data sources for different scroll regions. If you want that effect, I would suggest just using multiple UltraGrids and splitter bars. The closest you can do is for ColumnScrollRegion is to define ExclusiveColumnScrollRegion property on a column object to an active ColumnScrollRegion. Which that can show split but linked data in separate scroll regions.
    Hope that helps,
