40
How to multi select Column and Rows on Mouse over
We recently upgraded our Infragistcs version from 3.1 to 6.2 . In 3.1 we were able to use the mouse and drag and select 4 records.Now we are unable to use the mouse to multiselect the multiple records. But the keyboard (Ctrl + Downarrow ) works. Is there anything specfic that we need to
do handle in 6.2 version regarding mouse movements?
My Grid is of type CartView.
I am setting up the following property to  SelectTypeRow property =ExtendedAutoDrag , When I do this I am able to multi select the rows on mouse left click and drag. But When I click on the Column and start dragging , its not working.
Do I need to setup something else.
To be precise , its not working when I click on Column and drag rows from the left corner.
  • 45049
    I'm not sure I understand the problem.  It might help if you clarify what you mean by "click on the Column".  Do you mean a column header, or a particular cell?  Do you have a situation where this does approach work?  What if you turn CardView off?
    This may be a situation where screenshots may be helpful, to be clear about where you're clicking where row ("record") selection works, and where you're clicking where it doesn't.
    If this is an urgent issue, I suggest that you submit a support request to Infragistics Developer Support.  The forums are a peer-to-peer resource; while we'll provide what help as we can when we can, if you need official product support, submitting a support request is the way to go.
