80
Hotkey for label
I have a requirement to use different font color in the same text of label. (Example: The label text is "Name*" in which asterix should be marked RED.)
This is not possible using UltraLabel, so I am using UltraFormattedLinkLabel. But the problem with UltraFormattedLinkLabel is that it does not allow to add hotkey, which is possible through UltraLabel by adding ampersand as desired. (Example: "&Name*" for N to be the hotkey).
How do I achieve hotkey functionality as well as two font color in single label? Using two UltraLabels does not work, because the two label texts looks separated, with space between them.
