870
How to open a workbook saved in StrictOpenXml format
Our application has the need to open workbooks that have been saved in the StrictOpenXml format.  Calling the workbook's load method generates "Input string was not in a correct format." with the following stack dump.  Any help would be appreciated.
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseUInt32(String value, NumberStyles options, NumberFormatInfo numfmt)
   at Infragistics.Documents.OfficeOpenXml.Excel.NamespaceDefinitions.SpreadsheetMLMain.ReadCT_ColorElement(XmlPartManagerBase partManager, String elementName, Nullable`1& autoValue, Nullable`1& indexedValue, Nullable`1& rgbValue, Nullable`1& themeValue, Double& tintValue)
   at Infragistics.Documents.OfficeOpenXml.Excel.NamespaceDefinitions.SpreadsheetMLMain.ReadColorElement(XmlPartManagerBase partManager, Nullable`1& autoValue, Nullable`1& indexedValue, Nullable`1& rgbValue, Nullable`1& themeValue, Double& tintValue)
   at Infragistics.Documents.Excel.Serialization.Excel2007.XLSX.PartManagers.ObjectModelCommonPartHelpers.LoadColorElement(XmlPartManagerBase partManager)
   at Infragistics.Documents.OfficeOpenXml.Core.XmlReadManager.LoadChildElementsHelper(Int32 startStackDepth, Int32 currentChildIndex, AlternateContentStatus alternateContentStatus, Boolean isContinuation, Boolean justPopped)
   at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.<>c__DisplayClass8.<LoadCore>b__6()
   at Infragistics.Documents.Core.Async.If(Boolean condition, Func`1 statement, Func`1 elseStatement)
   at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.<LoadCore>b__5(XmlReader xmlReader)
   at Infragistics.Documents.Core.Async.UsingHelper`1.<Execute>b__a()
   at Infragistics.Documents.Core.Async.Try(Func`1 try, Action finally)
   at Infragistics.Documents.Core.Async.UsingHelper`1.Execute()
   at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.LoadCore()
   at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.<Load>b__0()
   at Infragistics.Documents.Core.Async.Try[TResult](Func`1 try, Action finally)
   at Infragistics.Documents.OfficeOpenXml.Core.PartManagers.XmlPartManagerBase.Load()
   at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.<>c__DisplayClass1a.<>c__DisplayClass1c.<>c__DisplayClass1e.<LoadPart>b__13(Stream partStream)
   at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.<>c__DisplayClass1a.<>c__DisplayClass1c.<>c__DisplayClass1e.<LoadPart>b__12()
   at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.<>c__DisplayClass1a.<>c__DisplayClass1c.<LoadPart>b__11()
   at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.<>c__DisplayClass1a.<LoadPart>b__10(WorkItem`1 t)
   at Infragistics.Documents.Core.WorkItemExtensions.<>c__DisplayClassc`1.<Then>b__b()
   at Infragistics.Documents.Core.WorkItem.WorkItemAsync.ExecuteCore(WorkItemScheduler scheduler)
   at Infragistics.Documents.Core.WorkItem.Execute(WorkItemScheduler scheduler)
--- End of stack trace from previous location where exception was thrown ---
   at TryThrowExceptionDispatchInfo(Object )
   at Infragistics.Documents.Core.WorkItem.ExceptionInfo.Rethrow()
   at Infragistics.Documents.Core.WorkItemExtensions.GetResult[TResult](WorkItem`1 this)
   at Infragistics.Documents.OfficeOpenXml.Core.OfficeDocumentManager.<LoadCore>b__b(WorkItem`1 t)
   at Infragistics.Documents.Core.Async.<>c__DisplayClass2`1.<Try>b__0(WorkItem`1 t)
   at Infragistics.Documents.Core.WorkItemExtensions.<>c__DisplayClass6`1.<Then>b__5()
   at Infragistics.Documents.Core.WorkItem.WorkItemSync.ExecuteCore(WorkItemScheduler scheduler)
   at Infragistics.Documents.Core.WorkItem.RunNextWorkItem(WorkItemScheduler scheduler)
   at Infragistics.Documents.Core.WorkItemScheduler.SynchronousImpl.Execute(WorkItem workItem)
   at Infragistics.Documents.Excel.Workbook.Load(String fileName, WorkbookLoadOptions loadOptions)
   at DMAXX.TheBooks.Controls.ReceiveLogItemViewer.DisplayReceiveLogItem(ReceiveLog pReceiveLog) in F:\TheBooks\TBClient\Controls\ReceiveLogItemViewer.vb:line 57
