295
UltraLiveTileView paint error on certain tile configurations
We use an UltraLiveTileView and in certain set-ups of tiles the component crashes during the painting. The component throws an System.IndexOutOfRangeException.
We have managed to reproduce the situation in the provided sample. The sample causes an exception on start-up. Resizing after loading causes the component not to be painted. Removing the initial size of 1200x800 causes the sample to start without an exception, but resizing the form causes the same issue.
The initialization of this UltraLiveTileView is done at runtime, not at design time. Is the component initialized wrong, or could this be considered a bug? If so, is there a work-around available?
WindowsFormsApplication1.zip
  • 12480
    Hi Jasper,
    Thanks for sending your sample. I ran it and I see the exception. If this was set up in the designer, it's unexpected and we will look into why it happens.
    I attempted to create a case for you, but it seems that there is some type of issue on our end. Our systems team is currently investigating why that's happening. For now, we will address this issue on this thread.
