I have one wingrid bound to a BindingSource. The data are correctly shown in the grid at runtime.
One of the columns of the grid is a varchar key that need to be decoded in a lookup table. So, I have a second BindingSource containing a couple key+description from this table. The BindingSource can be bound to a dropdown or a combo (I tried both) and the control is used as an editor for the grid's column (the description is the displaymember, the key is the valuemember). All is ok and I can change the values using the dropdown combo.
A problem raise when I navigate the records of the grid using the mouse instead of the keybord: randomly, the cell containing the drop down show a null string instead of the correct value when I change the current row clicking with thw mouse on a different row. It happens this way:
I tried different databases (mysq via odbc, access via oledb), different dropdown infragistics controls and binding methods (valuelist and editcontrol), but the bug is always there.
Is there a solution?
Yeah, I don't think you can get a hot fix on a trial version.
Thank you,
unfortunately I was evaluating the product (and using the last official version avaible on your site). I suppose I have no access to the fixed version.
This has already been fixed. Get the latest Hot Fix.
The text disappear because its foreColor haven't been refreshed properly.I found that this bug appears only when the cell's data is from a value list.
When you highlighting a row, the forecolor of the active row is white,means that the text's color is white. After you clicked another row, the forecolor of the former selected row should be changed to the black, but haven't. The forecolor becomes the same with the backcolor (both are white), so the text seems to disappear.
I think it's a bug of version 7.3 .It doesn't happen in version 7.2 .
In fact, I don't think it's something related to data structure. And the data are retrieved only once (during a form load). I'll try to use other types of lookup tables and if the bug persist I will send you an example. The strange is that only the mouse-click generate the problem.
