375
Read-only custom UltraTextEditor
Hello
 I am trying to create a custom control where I am using a text editor and I want it to be read-only and resemble a label (no border).  The reason for this is that users have to able to copy/paste from this read-only text box.  The problem is that even by setting BorderStyle=None or Solid with the same color as the background, the border is still visible.  What property do I have to set in order for my textbox not to have any border.
EP
  • 469350
    You are probably getting a border because of the operating system theme. Set UseOsThemes on the control to true and then you should be able to set the BorderStyle to None.
