3186
Merge Cells
Didn't see anything about merging cells except in the xam product.  Any plans to add to UltraSpreadsheet?
  • 469350
    Verified Answer
    Ultra(Win)Spreadsheet supports merged cells. Merging is defined in the Excel worksheet itself. So if you load a worksheet with merged cell, the UltraSpreadSheet will display the merged cells correct.
    You can merge cells in a worksheet in code using the worksheet.MergedCellRegions.Add method.
    And you can even use the PerformAction method on the UltraSpreadsheet to call several merging commands such as:
    Infragistics.Win.UltraWinSpreadsheet.UltraSpreadsheetAction.MergeCells
    Infragistics.Win.UltraWinSpreadsheet.UltraSpreadsheetAction.MergeCellsAcross
     Infragistics.Win.UltraWinSpreadsheet.UltraSpreadsheetAction.MergeCellsAndCenter
