85
Edit data in UltraCombo
My purpose is to use a combo as a list of checkboxes. The problem is that I have not possibility to modify the value of checkbox in the list.(With UltraGrid there is possiblity to do that, but I would like to use ultracombo because an ultracombo use less space on form.)
On UltraCombo it is possible to set CellClickAction on Edit value, but runtime there is an exception:
System.NotSupportedException: Cell activation not supported
   at Infragistics.Win.UltraWinGrid.UltraGridCell.SetFocusAndActivate(Boolean byMouse, Boolean enterEditMode, Boolean byTabKey)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.SetFocusAndActivate(Boolean byMouse, Boolean enterEditMode)
Private Sub testControl_InitializeLayout(sender As Object, e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles testControl.InitializeLayout
With e.Layout.Bands(0)
 .Columns("Value").CellActivation = Infragistics.Win.UltraWinGrid.Activation.AllowEdit
.Columns("Value").CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.Edit
.Columns("Value").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.CheckBox
 End With
End Sub
I would like to use ultracombo to modify data in datatable. Can I do this with ultracombo or I need another control for that purpose?
