When I double-click on a time-slot on the ultradayview to pop open my schedule editor, the Date of the StartTime of the selected appointment is one day earlier than the day showing on the ultradayview control.
The event handler I am using is as follows:
// Stop the default dialog from displaying
// Display encounter entry form
If I display the starttime in the dialog form, it is one day earlier than what shows in the ultradayview.
Why is this?
How do I fix this?
What am I doing wrong?
Thanks for your help in Advance.
Phil Curtiss
There is not enough information here to know what is causing the problem. If 'e.Appointment.StartDateTime.ToString() ' returns the expected value then something is going wrong when you "...display the starttime in the dialog form". If it doesn't then you should report this as a bug and include a test project so we can observe the problem.
