I would like to show data values on a 2D column chart (see attachment). Currently, I can do this on a 3D pie chart very easily, but I can't figure out how to make it happen on a 2D column chart. I can't use a 3D chart because there are times when a bank account might be overdrawn and have a negative value.
If you want to keep it simple you can replace the chartText.ItemFormatString from chartTextApp.ItemFormatString = "<DATA_VALUE:00.00>"; to chartTextApp.ItemFormatString = "<DATA_VALUE:#>"; but you'll lose some formatting. Otherwise you'll have to use IRenderLabel and do something like this:
Change ItemFormatString to something not reserved:
chartTextApp.ItemFormatString = "<MY_CUSTOM_LABEL>";
Create the IRenderLabel implementation:
public class MyLabelRenderer : Infragistics.UltraChart.Resources.IRenderLabel
public string ToString(Hashtable context)
double dataVal = (double)context["DATA_VALUE"];
if (dataVal <= 10.0)
return string.Empty;
return dataVal.ToString("0.00");
hook up the LabelHash like this:
Hashtable MyHashtable = new Hashtable();
MyHashtable.Add("MY_CUSTOM_LABEL", new MyLabelRenderer());
this.ultraChart1.LabelHash = MyHashtable;
Is there any way to conditionally display chart text? I don't want to show the text if the value is zero.
ChartText only applies to 2D chart appearance objects and is not supported on 3D ChartAppearance objects.
Can you point me in the right direction on how to do this for a 3D column chart?
Keep in mind the text won't flow outside the chart area bounds so your checking data value text may still get pushed down, you would have to add some extra space to the top by customizing the range on the y-axis.
