Hello there,
i am using the datachart more and more, and thus it seems i run into more and more Detail questions.
At this time i was taking care of zooming and have 2 questions
1) Can i change the Color (brush) of the zooming rectangle (outline) while using the mouse? One of my Charts Needs to have a black Background and the zooming rectangle cannot be ssen.
2) When drawing the zooming rectangle, while the left mouse button is down, i have an issue, when i Approach the x or y axis. I want to Setup the zooming rectangle by starting in the middle of the Chart, move the mouse down to the x-axis (so that i get each Point) and then move the mouse to the left. But movin the mouse left is not possible when having the mouse Cursor on or a Little bit underneath the x-axis line. This way of zooming is very Handy in my case. Is there a way to realize this?
I hope ist clear what i mean.
Thank you,
Thomas
When the PreviewPathStroke property was added it was only added for Windows forms and is a product idea for Ignite UI and you can suggest this on the ideas site.
Thanks Alan. I just realized I am on the wrong forum, I needed this for the igniteui igDataChart. We don't see such property in the 2017.1, do you know if such is available in igniteui? Thanks.
The PreviewPathStroke property is present in the latest service release of 2015 Volume 2 and 2016 Volume 1. It can also be expected in the release of 2016 Volume 2.
Thanks for adding the PreviewPathStroke property, it is exactly the feature I am looking for. I am currently on version 2015.2, I guessed this is not available until later versions. Which version did this property started to appear in? If upgrading is not possible immediately, are there any interim solutions that I can do in the meantime, like modifying a css or a js file? Thanks.
Hi Thomas,
Glad to hear it is working and the re-test looks good. Thanks for bringing the color of the zoom rect to our attention!
