I have a ultrawinexplorer bar in which I want to add my own usercontrol which contains a treeview that is dynamically created. I add it to a container and then I add the container to the Group of the winexplorer bar. I have also changed the Settings.Style property to ControlContainer. When I compile the code nothing goes wrong everything works fine. But, when I run the code, it does not show the added control on the explorer bar. Can you help me out here. I would appreciate if you can provide some sample code also alongwith the reply.
Thanks in Advance
Rushikesh
Hello Rushikesh,
Could you please review the sample attached to this post and see if it meets your requirements.
Please feel free to let me know if I misunderstood you or if you have any other questions.
