845
Automatically add character to editing cell, but dont fire Cell Update
Hi there,
I have this scenario: Client can define many sub-packs in Grid A, each being identified with a letter (sub code)
In grid B, client can build packs based on sub-packs, and in any combination.
The pack code must be constructed using the sub pack codes concatenated with a plus sign (+) e.g.
A
A+B
A+B+C
B+C+D
I would like the + sign to be automatic i.e. the user must type AB to get A+B, and BCD to get B+C+D, however duplicates are not allowed. I would like the + sign to be added without firing the cell update events, where the duplicates are tested.
Can this be accomplished? I have had no luck - Text property is read-only and cannot be set, and setting Value property fires Update.
Deon
  • 2575
    Verified Answer
    Hello Deon,
    Please take a look at the UltraGridCell.EditorResolved. By setting the EditorResolved.Textbox.Text you will not fire Update(). The following snippet demonstrates inserting "+" into the Editor's text:
    private void UltraGrid1_KeyUp(object sender, KeyEventArgs e)
                if (ultraGrid1.ActiveCell.IsInEditMode)
                    EditorWithText editor = (EditorWithText)ultraGrid1.ActiveCell.EditorResolved;
                    string text = editor.CurrentEditText;
                    if (text.Length > 1)
                        for (int i = 1; i < text.Length; i += 2)
                            if (text[i] != '+')
                                text = text.Insert(i, "+");
                        editor.TextBox.Text = text;
                        editor.SelectionStart = text.Length;
    Please let me know how I can be of further assistance.
